Introducción
Replacing the keyboard on your laptop can be necessary if your keyboard is no longer responding. You will need a nylon or metal spudger. Make sure that the power is off before continuing.
Qué necesitas
Rotate the laptop so the back side is facing you.
From this side, you should be able to see both of the gaps where the two plastic materials meet.
2 personas más completaron esta guía.
