Saltar al contenido principal
Lenovo IdeaPad S10-2 Key Replacement
Qué necesitas
  1. Lenovo IdeaPad S10-2 Key Replacement, Key: paso 1, imagen 1 de 1
    • Open the laptop so the keyboard is facing you.
  2. Lenovo IdeaPad S10-2 Key Replacement: paso 2, imagen 1 de 1
    • Use a spudger to remove the keys by wedging it underneath the key.
  3. Lenovo IdeaPad S10-2 Key Replacement: paso 3, imagen 1 de 1
    • Pull back the key to remove and separate the key from the metal bars underneath.
  4. Lenovo IdeaPad S10-2 Key Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad S10-2 Key Replacement: paso 4, imagen 2 de 2
    • Ensure the bars are in correctly before continuing. The end of the top bar should be in the hooks and the end of the bottom bar should go through the loops.
    • To install the new key, make sure the top bar is attached to the bottom of the key and push down until a click is heard.
Linea de Meta
Anthony
Miembro Desde 10/13/15
258 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 850
