Saltar al contenido principal
Lenovo IdeaPad S10-2 Hard Drive Replacement
Qué necesitas
  1. Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Start with laptop closed.
    • Turn laptop over so the back panel is visible, as shown in the second image.
    • Remove the two 40 mm Phillips screws using a Phillips J0 head screwdriver.
  2. Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Remove both 40 mm Phillips screws using a Phillips J0 head screwdriver.
    • Remove the back panel and set it aside.
  3. Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Remove the 40 mm screw using a Phillips J0 head screwdriver.
  4. Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 4, imagen 2 de 2
    • After removing the screw, carefully wedge the flat end of a spudger in the spacing to remove the hard drive from the port.
    • Pry the hard drive out of its port.
    • Push the wedged end of the spudger out as indicated by the action shots.
  5. Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Carefully lift the hard drive enclosure to remove it from the laptop.
    • The enclosure is the metal case holding the actual hard drive. You must remove the metal case in order to replace the hard drive.
  6. Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 6, imagen 1 de 3 Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 6, imagen 2 de 3 Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 6, imagen 3 de 3
    • The hard drive enclosure has four 40 mm screws keeping the hard drive in place.
    • Remove the four 40 mm screws with a Phillips J0 head screwdriver.
  7. Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 7, imagen 1 de 2 Lenovo IdeaPad S10-2 Hard Drive Replacement: paso 7, imagen 2 de 2
    • Slide the hard drive out of the enclosure.
    • The new hard drive can be inserted into the same enclosure.
Conclusión
Anthony
Miembro Desde 10/13/15
258 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 22
Todo El Tiempo: 9,497
