Saltar al contenido principal
Lenovo IdeaPad S10-2 Battery Replacement
  1. Lenovo IdeaPad S10-2 Battery Replacement, Battery: paso 1, imagen 1 de 2 Lenovo IdeaPad S10-2 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Start with the laptop upside down and the bottom panel facing up.
    • These two switches are used to remove the battery.
  2. Lenovo IdeaPad S10-2 Battery Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad S10-2 Battery Replacement: paso 2, imagen 2 de 2
    • Firmly push the two switches inward and toward each other.
    • When you push up on the battery it will come out of its port.
  3. Lenovo IdeaPad S10-2 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the battery.
    • To attach the new battery, push the battery back in the correct spot on the computer. You will hear a click once the battery is in place.
Linea de Meta
Faylin Riemer
Miembro Desde 10/13/15
101 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 1,908
