Introducción
Adding to or upgrading the RAM in a computer is a common way to improve its performance. This guide provides instructions on how to accomplish this.
Partes
No se requieren partes.
  1. Turn off laptop before beginning.
    • Turn off laptop before beginning.
    • Remove the five 5.0 mm Phillips #0 screws marked in this picture.
  2. Use the spudger to separate the bottom panel from the laptop case. It is recommended that you start from a corner and work your way around the panel. Be careful not to bend or break the bottom panel.
    • Use the spudger to separate the bottom panel from the laptop case.
    • It is recommended that you start from a corner and work your way around the panel.
    • Be careful not to bend or break the bottom panel.
  3. Lift up the right side of the case as shown, and slide it to the left to detach the case. The disk drive will remain attached to the bottom panel. Sliding the panel to the left disconnects it. To avoid damaging the disk drive connector, avoid lifting the right side of the panel too far up.
    • Lift up the right side of the case as shown, and slide it to the left to detach the case.
    • The disk drive will remain attached to the bottom panel. Sliding the panel to the left disconnects it.
    • To avoid damaging the disk drive connector, avoid lifting the right side of the panel too far up.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Remove the two 2.5mm Phillips #0 screws marked in this picture. Remove the two 2.5mm Phillips #0 screws marked in this picture. Remove the two 2.5mm Phillips #0 screws marked in this picture.
    • Remove the two 2.5mm Phillips #0 screws marked in this picture.
  6. Locate the battery connector. Using the pointy end of the spudger, press down on the middle tab of the connector to release the retaining clip. Work each side of the connector out until it comes completely out. Pull it free of the connector housing.
    • Locate the battery connector.
    • Using the pointy end of the spudger, press down on the middle tab of the connector to release the retaining clip.
    • Work each side of the connector out until it comes completely out. Pull it free of the connector housing.
    • There is still a live current in the battery. Use a plastic tool to pull the battery connector.
  7. The battery can now be lifted from the laptop case. The battery can now be lifted from the laptop case.
    • The battery can now be lifted from the laptop case.
  8. Pull the tabs on either side of the top RAM stick outwards. The RAM stick will pop up, and can be removed. Pull the tabs on either side of the top RAM stick outwards. The RAM stick will pop up, and can be removed. Pull the tabs on either side of the top RAM stick outwards. The RAM stick will pop up, and can be removed.
    • Pull the tabs on either side of the top RAM stick outwards. The RAM stick will pop up, and can be removed.
  9. As with the top stick, pull the tabs on  either side of the lower stick out until it pops up, and remove it. As with the top stick, pull the tabs on  either side of the lower stick out until it pops up, and remove it. As with the top stick, pull the tabs on  either side of the lower stick out until it pops up, and remove it.
    • As with the top stick, pull the tabs on either side of the lower stick out until it pops up, and remove it.
Conclusión
Hi. In the first step you did not notice the screws under the square rubber base, actually 4th bases.
Roberto Quesada - Contestar
I really sorry, but this post is wrong.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 8
Todo El Tiempo: 71
