Introducción
Batteries lose their capacity over time, greatly reducing the portability of a laptop. This guide provides instructions for removing the battery and replacing or upgrading it.
Partes
No se requieren partes.
  1. Turn off laptop before beginning.
    • Turn off laptop before beginning.
    • Remove the five 5.0 mm Phillips #0 screws marked in this picture.
  2. Use the spudger to separate the bottom panel from the laptop case. It is recommended that you start from a corner and work your way around the panel. Be careful not to bend or break the bottom panel.
    • Use the spudger to separate the bottom panel from the laptop case.
    • It is recommended that you start from a corner and work your way around the panel.
    • Be careful not to bend or break the bottom panel.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Lift up the right side of the case as shown, and slide it to the left to detach the case. The disk drive will remain attached to the bottom panel. Sliding the panel to the left disconnects it. To avoid damaging the disk drive connector, avoid lifting the right side of the panel too far up.
    • Lift up the right side of the case as shown, and slide it to the left to detach the case.
    • The disk drive will remain attached to the bottom panel. Sliding the panel to the left disconnects it.
    • To avoid damaging the disk drive connector, avoid lifting the right side of the panel too far up.
  5. Remove the two 2.5mm Phillips #0 screws marked in this picture. Remove the two 2.5mm Phillips #0 screws marked in this picture. Remove the two 2.5mm Phillips #0 screws marked in this picture.
    • Remove the two 2.5mm Phillips #0 screws marked in this picture.
  6. Locate the battery connector. Using the pointy end of the spudger, press down on the middle tab of the connector to release the retaining clip. Work each side of the connector out until it comes completely out. Pull it free of the connector housing.
    • Locate the battery connector.
    • Using the pointy end of the spudger, press down on the middle tab of the connector to release the retaining clip.
    • Work each side of the connector out until it comes completely out. Pull it free of the connector housing.
    • There is still a live current in the battery. Use a plastic tool to pull the battery connector.
  7. The battery can now be lifted from the laptop case. The battery can now be lifted from the laptop case.
    • The battery can now be lifted from the laptop case.
Conclusión
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 12
Últimos 30 Días: 30
Todo El Tiempo: 104
