Introducción
This task will require you to disassemble the laptop and work with small connectors and wires. It is important to make sure that you follow the steps to remove the battery and keep the laptop unplugged while working on it. This will help avoid damaging the electronics.
Qué necesitas
Remove the two 14mm Phillips #1 screws that attach the keyboard to the underside of the laptop.
Flip the laptop so that the bottom faces up.
You will first need to remove three 7mm Phillips #1 screws from the bottom of the laptop.
