Introducción
Removing the RAM is a simple process. Be sure that you follow the steps to remove or disconnect the battery and keep the laptop unpowered to avoid damaging the electronics inside.
Herramientas
Partes
No se especificaron partes.
Remove the two 14mm Phillips #1 screws that attach the keyboard to the underside of the laptop.
Flip the laptop so that the bottom faces up.
You will first need to remove three 7mm Phillips #1 screws from the bottom of the laptop.
Pull outward on both clips on the sides of the top RAM to release it.
The RAM will pop up slightly if you have pulled the clips out properly.
