Introducción
If your RAM is insufficient or failing, you may want to replace or upgrade it by following this guide.
Partes
No se requieren partes.
  1. Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
    • Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
  2. Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
    • Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
  3. Now take your left hand and slide the left switch to the left.
    • Now take your left hand and slide the left switch to the left.
    • This switch will not click in place like the other switch, so make sure to keep your left hand on the switch.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Take your free hand and place it on the battery. Gently slide it away from its slot.
    • Take your free hand and place it on the battery. Gently slide it away from its slot.
  6. Rotate the laptop so that now the hinge is facing away from you.
    • Rotate the laptop so that now the hinge is facing away from you.
    • Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
  7. Slide the bottom panel towards you until it stops, and then carefully lift it off. Slide the bottom panel towards you until it stops, and then carefully lift it off.
    • Slide the bottom panel towards you until it stops, and then carefully lift it off.
  8. The RAM sticks can be found at the bottom right of the laptop. Carefully press the two silver buttons on either side of the stick outwards. This will cause the RAM to “pop” up. This device is capable of holding two RAM sticks, so there are two different sets of silver buttons; a top set and a bottom set. When removing the RAM stick, make sure to press either the two bottom buttons or the two top buttons.
    • The RAM sticks can be found at the bottom right of the laptop.
    • Carefully press the two silver buttons on either side of the stick outwards. This will cause the RAM to “pop” up.
    • This device is capable of holding two RAM sticks, so there are two different sets of silver buttons; a top set and a bottom set. When removing the RAM stick, make sure to press either the two bottom buttons or the two top buttons.
  9. Carefully slide the RAM straight out of its socket.
    • Carefully slide the RAM straight out of its socket.
Conclusión
Alex Amorim
Miembro Desde 19/03/18
697 Reputación
5 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 11
Todo El Tiempo: 97
