Saltar al contenido principal
Lenovo IdeaPad G50-45 Fan Replacement
Qué necesitas
  1. Lenovo IdeaPad G50-45 Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Safely flip the device upside down and use the Phillips head screwdriver to remove the 3 screws at the bottom of the device which are circled.
  2. Lenovo IdeaPad G50-45 Fan Replacement: paso 2, imagen 1 de 1
    • Slide, do not lift, the bottom panel off once the 3 screws are off.
  3. Lenovo IdeaPad G50-45 Fan Replacement: paso 3, imagen 1 de 1
    • Locate the fan in the upper right corner above the orange bar and appears as a silver semicircle.
  4. Lenovo IdeaPad G50-45 Fan Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad G50-45 Fan Replacement: paso 4, imagen 2 de 2
    • Remove the 3 screws attaching the fan to the device.
  5. Lenovo IdeaPad G50-45 Fan Replacement: paso 5, imagen 1 de 1
    • Once the screws are removed slowly lift the fan out, there will be a thin wire connected to the device and fan still, Firmly grasp the white end of the wire where the wire splits into 2 and pull it out.
  6. Lenovo IdeaPad G50-45 Fan Replacement: paso 6, imagen 1 de 1
    • The fan should be removed now and appear as so.
Conclusión
3 personas más completaron esta guía.
Robert Muir
Miembro Desde 10/26/15
359 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Miembro de UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 2,961
