Saltar al contenido principal
Lenovo IdeaPad G50-45 DVD Drive Replacement
Qué necesitas
  1. Lenovo IdeaPad G50-45 DVD Drive Replacement, DVD Drive: paso 1, imagen 1 de 1
    • First, remove the three screws located on the bottom panel of the laptop using a Philips #2 screwdriver.
    • To avoid losing the small screws, put them in a container.
  2. Lenovo IdeaPad G50-45 DVD Drive Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad G50-45 DVD Drive Replacement: paso 2, imagen 2 de 2
    • To remove the panel on the laptop, gently slide the panel away from the battery.
    • Make sure to slide the panel away before you lift to keep the panel from breaking.
    • Lift up the panel and place it to the side.
  3. Lenovo IdeaPad G50-45 DVD Drive Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad G50-45 DVD Drive Replacement: paso 3, imagen 2 de 2
    • Remove the indicated screw holding the DVD Drive.
    • To avoid losing the screw, place it in the same container used to hold the other three screws.
  4. Lenovo IdeaPad G50-45 DVD Drive Replacement: paso 4, imagen 1 de 1
    • Push the now-free tab towards the DVD Drive using a flathead screwdriver.
    • Do not pry up the now-free tab.
  5. Lenovo IdeaPad G50-45 DVD Drive Replacement: paso 5, imagen 1 de 1
    • Lastly, pull out the DVD Drive; it should come out easily.
Conclusión
6 personas más completaron esta guía.
Saulo Gomes
Miembro Desde 10/26/15
601 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Miembro de UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 8,470
