Saltar al contenido principal
Lenovo IdeaPad Flex 6-14IKB Speakers Replacement
Qué necesitas
  1. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement, Base Cover: paso 1, imagen 1 de 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement, Speakers: paso 3, imagen 1 de 2 Lenovo IdeaPad Flex 6-14IKB Speakers Replacement, Speakers: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Unplug the wire connector from the speaker using the tweezers.
  4. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: paso 4, imagen 2 de 2
    • Lift the right side speaker off of the pins that the speaker is resting on using an iFixit opening tool.
  5. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: paso 5, imagen 1 de 1
    • Unwind the red and black wire that connects the two speakers from the plastic clips that secure it.
  6. Lenovo IdeaPad Flex 6-14IKB Speakers Replacement: paso 6, imagen 1 de 1
    • Lift the left side speaker off of the pins that the speaker is resting on using an iFixit opening tool.
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 148
