Saltar al contenido principal
Lenovo IdeaPad Flex 6-14IKB RAM Replacement
Qué necesitas
  1. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, Base Cover: paso 1, imagen 1 de 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, RAM: paso 3, imagen 1 de 1
    • Use the plastic opening tool to pry the protective cover off of the RAM.
  4. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: paso 4, imagen 2 de 2
    • Unfasten the metal clips that secure the RAM.
  5. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: paso 5, imagen 1 de 3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: paso 5, imagen 2 de 3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: paso 5, imagen 3 de 3
    • Remove the RAM from its slot on the motherboard.
Conclusión
Un comentario
Thank you so much
Ayham Ka - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 43
Todo El Tiempo: 767
