Introducción
If you want to upgrade the SSD card in your Lenovo IdeaPad Flex 5-1470, use this guide to replace the SSD card. The SSD card in the Lenovo IdeaPad Flex 5-1470 is connected to the device’s motherboard.
Before replacing the SSD in your Lenovo IdeaPad Flex 5-1470, research which SSD cards are compatible with the device.
The only step to do before removing the SSD card is to remove the device’s back panel.
Herramientas
Remove one 3.6 mm screw using the Phillips 00 screwdriver.
The SSD will pop up on its own after removing the screw.
Casi Terminas!
Conclusión
