Qué necesitas
Use a Phillips #00 screwdriver to remove the three screws securing the fan.
Lift the fan up and out.
Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
Lift the hard drive up and out.
Use a Phillips #00 screwdriver to remove the four 5 mm screws from the left and right hinges (two screws on each hinge).
Disconnect the display assembly from the rest of the device by separating the hinges of the display from the body of the laptop.
Use a spudger to carefully pry loose the two screw covers (one on each hinge).
Use a Phillips #00 screwdriver to remove the two 3 mm screws from the display (one on each side).
Una persona más ha completado esta guía.
