Introducción
Is your Lenovo IdeaPad Flex 5 14ARE05 overheating or crashing? A cooling fan malfunction could be what's causing it. Replacing the cooling fan is a quick and easy solution that could offer immediate results. Use this guide to remove and replace it. Before starting make sure your laptop is powered down and disconnected from any power sources.
Qué necesitas
Remove the five 8 mm screws using a T5 Torx Screwdriver.
Remove the four 5 mm screws using a T5 Torx Screwdriver.
Remove the four 2 mm screws using a JIS #1 screwdriver.
Remove the three 5 mm screws using a JIS #1 screwdriver.
