Saltar al contenido principal
Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement
Qué necesitas
  1. Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 2 Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the five 8 mm screws using a T5 Torx Screwdriver.
    • Remove the four 5 mm screws using a T5 Torx Screwdriver.
  2. Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: paso 2, imagen 1 de 3 Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: paso 2, imagen 2 de 3 Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: paso 2, imagen 3 de 3
    • Use a small suction cup to pull open the back case at the two hinge cutouts.
    • Gently, use the plastic opening tool around the edges of the laptop to pry up the rest of the back panel.
  3. Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: paso 3, imagen 1 de 1
    • Once all the clips have been disengaged, lift off the back cover.
Conclusión
5 personas más completaron esta guía.
Tyler Schrock
Miembro Desde 11/02/20
458 Reputación
2 Guías creadas
3 comentarios
This guide has been very helpful but I have a problem with missing screws 3 have fallen out now. and I see the guide doesn't list any parts so where could I go to find the screws?
Timothy Alper - Contestar
Same issue (on a Lenovo ChromeBook Flex 5 ‎82B80006UX). I'm guessing a M2 or M2.5 x 5mm & 8mm. I'm ordering some assorted screws & I'll post if any seem to really hit the size.
BenBen7 -
Hi. Why do some laptops have some kind of a sheet of paper blocking some part of their bottom vents, leaving a hole only for the fan intake? Is it safe to remove the paper?
Haris Sahlan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 97
Todo El Tiempo: 2,906
