Introducción
The wifi card allows for the laptop to connect to the internet via wireless connection. It can be removed with reasonable ease and is important for any usage of the laptop requiring online access.
Partes
No se requieren partes.
  1. Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body. Follow along the back edge with the plastic opening tool, lifting the cover off. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the foam on the WIFI card.
    • Remove the foam on the WIFI card.
  5. Remove the wires attached to the WIFI card.
    • Remove the wires attached to the WIFI card.
  6. Unscrew the 4mm screw holding  wifi card.
    • Unscrew the 4mm screw holding wifi card.
Conclusión
Elijah Ellis
Miembro Desde 08/11/18
514 Reputación
5 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 6
Todo El Tiempo: 71
