Introducción
This hub, located along the side of the laptop, allows for external storage and peripherals to be connect to the computer. It is relatively simple to replace, and is not inherently necessary for most day-to-day usage of the laptop.
Partes
No se requieren partes.
  1. Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body. Follow along the back edge with the plastic opening tool, lifting the cover off. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the 4mm screw with a JIS #0 screwdriver. Remove the 4mm screw with a JIS #0 screwdriver.
    • Remove the 4mm screw with a JIS #0 screwdriver.
  5. Remove the ribbon cable.
    • Remove the ribbon cable.
  6. Remove the existing USB hub and replace it with the new hub.
    • Remove the existing USB hub and replace it with the new hub.
Conclusión
Elijah Ellis
Miembro Desde 08/11/18
514 Reputación
5 Guías creadas
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 3
Todo El Tiempo: 75
