Saltar al contenido principal
Lenovo IdeaPad Flex 4-1470 Removing the Lower Case
Qué necesitas
  1. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case, Lower Case: paso 1, imagen 1 de 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: paso 2, imagen 1 de 2 Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: paso 2, imagen 2 de 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
Conclusión
6 personas más completaron esta guía.
Demario Robinson
Miembro Desde 10/02/17
1,038 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S1-G6, Thompson Fall 2017 Miembro de USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Miembros
10 Guías creadas
Un comentario
can someone please tell me where to find the back cover? i need to order it
angel etoile - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 18
Ultimos 30 días: 74
Todo El Tiempo: 19,173
