Saltar al contenido principal
Introducción
If you are experiencing a delay between touching the touchpad and actual movement of the mouse on screen or a complete lack of mouse movement, a touchpad replacement might be needed.
Partes
No se especificaron partes.
  1. Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Remove the connector attaching the battery to the motherboard.
    • Remove the connector attaching the battery to the motherboard.
  4. Remove the four 4mm screws on the battery.
    • Remove the four 4mm screws on the battery.
  5. Lift the battery with a spudger and remove.
    • Lift the battery with a spudger and remove.
  6. Remove eleven 6mm screws.
    • Remove eleven 6mm screws.
  7. Lift up black flap on the ZIF connector and pull the ribbon cable out.
    • Lift up black flap on the ZIF connector and pull the ribbon cable out.
  8. Lift up on the black tab on the ZIF connector and pull the ribbon cable out.
    • Lift up on the black tab on the ZIF connector and pull the ribbon cable out.
  9. Remove connector cable.
    • Remove connector cable.
  10. Remove one last connector cable.
    • Remove one last connector cable.
    • Motherboard should now be completely disconnected and can be lifted off the cover to be replaced.
  11. Due to the amount of force required to remove the screws holding the touchpad, we recommend removing the motherboard before attempting this replacement to reduce the chances of damaging any components.
    • Due to the amount of force required to remove the screws holding the touchpad, we recommend removing the motherboard before attempting this replacement to reduce the chances of damaging any components.
    • Lift up the black tab on the ZIF connector and pull the ribbon cable out.
  12. Remove three 8mm screws. Remove three 8mm screws.
    • Remove three 8mm screws.
  13. Push the touchpad outwards to remove it.
    • Push the touchpad outwards to remove it.
Conclusión
Adrian Miranda
Miembro Desde 15/02/18
677 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S17-G5, Boczar Spring 2018 Miembro de USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 11
Todo El Tiempo: 274
