Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Your screen might need replacement if there are any noticeable cracks on screen or if you are experiencing persistent flickering during use of your Lenovo IdeaPad Flex4-1130.
Partes
No se especificaron partes.
  1. Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Remove the connector attaching the battery to the motherboard.
    • Remove the connector attaching the battery to the motherboard.
  4. Remove the four 4mm screws on the battery.
    • Remove the four 4mm screws on the battery.
  5. Lift the battery with a spudger and remove.
    • Lift the battery with a spudger and remove.
  6. SALTEA LA ACTUALIZACIÓN
    Ahorra reparando con un kit todo en uno.
    Compra Kits de Reparación
  7. Remove six 7mm screws. Remove six 7mm screws.
    • Remove six 7mm screws.
  8. Remove two connector cables. Separate the two unhinged parts.
    • Remove two connector cables.
    • Separate the two unhinged parts.
  9. Use the spudger to remove the plastic caps, uncovering the screws underneath.
    • Use the spudger to remove the plastic caps, uncovering the screws underneath.
    • Remove the two 6mm screws.
  10. Use the black nylon spudger to remove the long plastic covering underneath the screen. Remove three 6mm screws.
    • Use the black nylon spudger to remove the long plastic covering underneath the screen.
    • Remove three 6mm screws.
  11. Use the black nylon spudger to lift and separate the screen from the plastic back cover. Use the black nylon spudger to lift and separate the screen from the plastic back cover.
    • Use the black nylon spudger to lift and separate the screen from the plastic back cover.
  12. Peel off tape and remove the cable. Peel off tape and remove the cable.
    • Peel off tape and remove the cable.
  13. Remove the connector chip. Remove the connector chip.
    • Remove the connector chip.
  14. Peel tape and remove cable underneath. Peel tape and remove cable underneath.
    • Peel tape and remove cable underneath.
Conclusión
Adrian Miranda
Miembro Desde 15/02/18
677 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S17-G5, Boczar Spring 2018 Miembro de USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 30
Todo El Tiempo: 1,103
