Saltar al contenido principal
Introducción
Replacing the battery on the Lenovo Ideapad Flex4-1130 is a relatively simple task with minimal risk of damaging the device. The battery might need replacement if your device is unable to remain on for very long even after being fully charged.
  1. Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Remove the connector attaching the battery to the motherboard.
    • Remove the connector attaching the battery to the motherboard.
  4. Remove the four 4mm screws on the battery.
    • Remove the four 4mm screws on the battery.
  5. Lift the battery with a spudger and remove.
    • Lift the battery with a spudger and remove.
Conclusión
Adrian Miranda
Miembro Desde 15/02/18
677 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S17-G5, Boczar Spring 2018 Miembro de USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 58
Todo El Tiempo: 615
