Saltar al contenido principal
Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement
Qué necesitas
  1. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement, Battery: paso 1, imagen 1 de 1
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: paso 2, imagen 1 de 1
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: paso 3, imagen 1 de 1
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: paso 4, imagen 2 de 2
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  5. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: paso 5, imagen 1 de 1
    • The battery is completely removed, and can be replaced with a new battery.
  6. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement, Touchpad: paso 6, imagen 1 de 1
    • After battery is removed, you will move to the touchpad.
  7. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: paso 7, imagen 1 de 1
    • Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
  8. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: paso 8, imagen 1 de 2 Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: paso 8, imagen 2 de 2
    • Remove all the screws holding the touchpad down.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 576
