Saltar al contenido principal
Lenovo IdeaPad 5 14ARE05 SSD Replacement
Qué necesitas
  1. Lenovo IdeaPad 5 14ARE05 SSD Replacement, SSD: paso 1, imagen 1 de 2 Lenovo IdeaPad 5 14ARE05 SSD Replacement, SSD: paso 1, imagen 2 de 2
    • Place your laptop with the bottom facing up.
    • Remove the three 9.3 mm screws from the upper side of the laptop using a T5 Torx screwdriver.
    • Remove four 4.5 mm screws from the lower side of the laptop using a T5 Torx screwdriver.
  2. Lenovo IdeaPad 5 14ARE05 SSD Replacement: paso 2, imagen 1 de 1
    • Use a Jimmy to pry open the back cover.
  3. Lenovo IdeaPad 5 14ARE05 SSD Replacement: paso 3, imagen 1 de 3 Lenovo IdeaPad 5 14ARE05 SSD Replacement: paso 3, imagen 2 de 3 Lenovo IdeaPad 5 14ARE05 SSD Replacement: paso 3, imagen 3 de 3
    • Remove the black sticker from the SSD.
    • Remove the single 4 mm screw from the SSD using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad 5 14ARE05 SSD Replacement: paso 4, imagen 1 de 1
    • The SSD, once unscrewed, will be angled at about 45 degrees.
    • Remove the SSD from its socket.
  5. Lenovo IdeaPad 5 14ARE05 SSD Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad 5 14ARE05 SSD Replacement: paso 5, imagen 2 de 2
    • Align your new SSD with the notches on the laptop and insert it at a 45 degree angle, just as it was when you removed it.
    • You'll know the SSD is inserted correctly once you no longer see the gold pins and the half circle at the other end of the SSD aligns with the screw hole.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 56
Todo El Tiempo: 336
