Saltar al contenido principal
Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement
Qué necesitas
  1. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement, USB/SD Ports: paso 1, imagen 1 de 1
    • Begin by placing your laptop upside down so that you can see the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: paso 2, imagen 1 de 1
    • Remove the 10 silver screws from the bottom of the laptop.
    • Keep these screws in a safe place like a magnetic board to keep them from getting lost.
    • (Silver, 5.8mm Phillips #0)
  3. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: paso 3, imagen 1 de 1
    • Carefully remove the back panel from the laptop.
    • Proceed slowly and use wedges to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: paso 4, imagen 1 de 1
    • Locate the USB/SD Ports in the top left corner of the laptop.
  5. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: paso 5, imagen 1 de 1
    • Remove the two black screws holding the USB/SD port in place.
    • (Black, 3.35mm Phillips #0)
  6. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: paso 6, imagen 1 de 1
    • Gently disconnect the black and red wires from the board.
    • Be sure not to pull too hard on the wires.
  7. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: paso 7, imagen 1 de 1
    • Remove the blue cable from the board.
  8. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: paso 8, imagen 1 de 1
    • Remove your old USB/SD ports
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 87
