Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lenovo IdeaPad 330S NVMe Drive Replacement
Qué necesitas
  1. Lenovo IdeaPad 330S NVMe Drive Replacement, NVMe Drive/Sata SSD: paso 1, imagen 1 de 2 Lenovo IdeaPad 330S NVMe Drive Replacement, NVMe Drive/Sata SSD: paso 1, imagen 2 de 2
    • Turn off the device before working on it.
    • Remove the 10 screws as shown in the picture
    • Gently using the tool pry off the bottom case
  2. Lenovo IdeaPad 330S NVMe Drive Replacement, Disconnecting Battery: paso 2, imagen 1 de 1
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery.
  3. Lenovo IdeaPad 330S NVMe Drive Replacement: paso 3, imagen 1 de 1
    • Remove the 4 screws according this picture
    • Gently pry out the black case.
  4. Lenovo IdeaPad 330S NVMe Drive Replacement: paso 4, imagen 1 de 1
    • Remove the Screw as shown in picture
    • The drive will lift, remove gently the drive.
    • Install the new drive and screw it to the motherboard
Conclusión
6 personas más completaron esta guía.
Ilia Tocheny
Miembro Desde 04/30/19
1,850 Reputación
9 Guías creadas
7Guía Comentarios
Is this machine compatible with both NVMe SSD and SATA SSD on the M2 port? Thank you.
notyourITguy - Contestar Compartir
This machine is compatible NVMe and Sata drive.
Ilia Tocheny - Compartir
mine came with m2 2242 ssd and is reaching its lifespan, can I replace it with m2 2280?
Kaizoku 62 - Contestar Compartir
Yes you can but before you do this… make sure to backup all data before doing the upgrade. When you will install the new ssd make you sure it is Nvme gen 3 and not gen4.
Samsung 980 is recommended ssd for the upgrade…
Ilia Tocheny - Contestar Compartir
any reason why I cannot install nvme gen4? its the same price as gen3
isnt it backwards compatible?
Kaizoku 62 - Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 68
Todo El Tiempo: 6,475
