Saltar al contenido principal
Lenovo IdeaPad 330-15AST RAM Replacement
Qué necesitas
  1. Lenovo IdeaPad 330-15AST RAM Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Remove the 7 mm Phillips screw from the back of the laptop which holds the optical drive in place.
  2. Lenovo IdeaPad 330-15AST RAM Replacement: paso 2, imagen 1 de 1
    • Carefully pull the optical drive out from the laptop.
  3. Lenovo IdeaPad 330-15AST RAM Replacement, Back Cover: paso 3, imagen 1 de 1
    • Remove the twelve 7 mm Phillips screw from the back of the device.
  4. Lenovo IdeaPad 330-15AST RAM Replacement: paso 4, imagen 1 de 1
    • Use opening picks or a plastic pry tool to remove the cover on all sides then lift.
  5. Lenovo IdeaPad 330-15AST RAM Replacement, RAM: paso 5, imagen 1 de 1
    • Pull the metal arms out slightly that hold the RAM secure by applying pressure with your finger.
  6. Lenovo IdeaPad 330-15AST RAM Replacement: paso 6, imagen 1 de 1
    • Slide the RAM stick out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 16
Ultimos 30 días: 28
Todo El Tiempo: 569
