Saltar al contenido principal
Lenovo IdeaPad 330-15AST Battery Replacement
Qué necesitas
  1. Lenovo IdeaPad 330-15AST Battery Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Remove the 7 mm Phillips screw from the back of the laptop which holds the optical drive in place.
  2. Lenovo IdeaPad 330-15AST Battery Replacement: paso 2, imagen 1 de 1
    • Carefully pull the optical drive out from the laptop.
  3. Lenovo IdeaPad 330-15AST Battery Replacement, Back Cover: paso 3, imagen 1 de 1
    • Remove the twelve 7 mm Phillips screw from the back of the device.
  4. Lenovo IdeaPad 330-15AST Battery Replacement: paso 4, imagen 1 de 1
    • Use opening picks or a plastic pry tool to remove the cover on all sides then lift.
  5. Lenovo IdeaPad 330-15AST Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Detach the battery pack connector from the motherboard using your fingers or an opening tool.
  6. Lenovo IdeaPad 330-15AST Battery Replacement: paso 6, imagen 1 de 1
    • Remove the four 7 mm Phillips screws surrounding the battery.
  7. Lenovo IdeaPad 330-15AST Battery Replacement: paso 7, imagen 1 de 1
    • Remove the battery.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 29
Todo El Tiempo: 1,073
