Saltar al contenido principal
Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 1 de 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 2 de 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 3 de 3
    • Remove the two Wi-Fi card's connections by gently lifting up on the connectors.
  4. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: paso 4, imagen 1 de 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: paso 4, imagen 2 de 3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: paso 4, imagen 3 de 3
    • Remove the single Phillips #0 screw securing the Wi-Fi card.
  5. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: paso 5, imagen 2 de 2
    • Slide the Wi-Fi card out of its port on the motherboard.
    • Do not worry about the angle the card sits after removing the mounting screw - this is how it's meant to be connected and will have to be connected similarly during reassembly.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 22
Todo El Tiempo: 284
