Saltar al contenido principal
Introducción
Replace the battery of your Lenovo IdeaPad 310 Touch-15ISK. This simple guide will describe how to access and remove the internal battery for replacement. The battery is fairly buried within the computer so the removal of major components is required.
Partes
No se especificaron partes.
  1. Lenovo IdeaPad 310 Touch-15ISK Battery Replacement, Battery: paso 1, imagen 1 de 2 Lenovo IdeaPad 310 Touch-15ISK Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over and remove the 13 Phillips #1 screws from the bottom panel.
    • Remove the 3 Phillips #1 screws holding RAM panel in and then remove RAM panel
  2. Lenovo IdeaPad 310 Touch-15ISK Battery Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 310 Touch-15ISK Battery Replacement: paso 2, imagen 2 de 2
    • Disconnect keyboard and touchpad wire using a soft pry bar.
    • Remove CD port.
  3. Lenovo IdeaPad 310 Touch-15ISK Battery Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad 310 Touch-15ISK Battery Replacement: paso 3, imagen 2 de 2
    • Flip laptop back over.
    • Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
  4. Lenovo IdeaPad 310 Touch-15ISK Battery Replacement: paso 4, imagen 1 de 3 Lenovo IdeaPad 310 Touch-15ISK Battery Replacement: paso 4, imagen 2 de 3 Lenovo IdeaPad 310 Touch-15ISK Battery Replacement: paso 4, imagen 3 de 3
    • Remove the 4 Phillips #0 screws holding the motherboard to the computer.
    • Disconnect the fan tab on the bottom of the motherboard.
    • Remove the 5 tabs holding the motherboard to the computer and remove the motherboard.
  5. Lenovo IdeaPad 310 Touch-15ISK Battery Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad 310 Touch-15ISK Battery Replacement: paso 5, imagen 2 de 2
    • Unscrew the 2 Phillips #0 screws holding the battery in place.
    • Remove wire tab holding battery in place.
    • Carefully remove battery.
Conclusión
5 personas más completaron esta guía.
Cam Plute
Miembro Desde 26/09/17
225 Reputación
1 Guía escrita
4 comentarios
Step 2 should include removing connectors for the wireless card.
Ronn Richardson - Contestar
Thanks for your commentary, I have added this in my French translation but I don’t know why I can’t modify the tutorial in English.. Maybe because I am a French member..
Zacharie Troletti-Gillot -
The fan should also be disconnected in step 2 not step 4.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 35
Ultimos 30 días: 158
Todo El Tiempo: 20,406
