Saltar al contenido principal
Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement
Qué necesitas
  1. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Bottom Back Cover: paso 1, imagen 1 de 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: paso 2, imagen 2 de 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Wireless LAN Card: paso 3, imagen 1 de 1
    • The wireless LAN card is located at the center of the laptop.
  4. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: paso 4, imagen 1 de 1
    • Unscrew the 3mm Phillips #1 screw that holds the WLAN card in place.
  5. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: paso 5, imagen 1 de 1
    • Disconnect the black and white cables from the WLAN card.
  6. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: paso 6, imagen 1 de 1
    • Gently remove the WLAN card out of its slot.
Conclusión
3 personas más completaron esta guía.
Ammar Dodin
Miembro Desde 01/19/17
1,057 Reputación
6 Guías creadas
Equipo
UC Davis, Team 1-3, Rodger Winter 2017 Miembro de UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Miembros
6 Guías creadas
3 comentarios
Thanks Ammar, I thought my wifi card was jammed until I saw your post.
Turns out one of the cables (white one) was disconnected which lead to my wifi signal being non-existent. I plugged it in again and its working properly again.
Cheers
Vlottie
David Vlotman - Contestar
Thanks for say, white is 1
SABBIR HOSSAIN -
How to connect wire black and white to pin 1 and 2, plz help
SABBIR HOSSAIN - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 2,798
