Saltar al contenido principal
Lenovo IdeaPad 300-17ISK RAM Replacement
Qué necesitas
  1. Lenovo IdeaPad 300-17ISK RAM Replacement, Bottom Back Cover: paso 1, imagen 1 de 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK RAM Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 300-17ISK RAM Replacement: paso 2, imagen 2 de 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK RAM Replacement, RAM: paso 3, imagen 1 de 1
    • The RAM sticks are located near the bottom of the device, and they are arranged next to each other.
  4. Lenovo IdeaPad 300-17ISK RAM Replacement: paso 4, imagen 1 de 3 Lenovo IdeaPad 300-17ISK RAM Replacement: paso 4, imagen 2 de 3 Lenovo IdeaPad 300-17ISK RAM Replacement: paso 4, imagen 3 de 3
    • Locate the two dislocating latches on each side of the stick and place your fingers on them.
    • Pull the tabs away from the stick simultaneously until the stick pops out of place.
    • Gently remove the RAM stick once it has popped out of its place.
    • If necessary, repeat the same process with the second RAM stick that is adjacent to the first one.
Conclusión
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
Una persona más ha completado esta guía.
Ammar Dodin
Miembro Desde 01/19/17
1,057 Reputación
6 Guías creadas
Equipo
UC Davis, Team 1-3, Rodger Winter 2017 Miembro de UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 24
Todo El Tiempo: 2,456
