Saltar al contenido principal
Lenovo IdeaPad 300-17ISK Optical Drive Replacement
Qué necesitas
  1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Keyboard: paso 1, imagen 1 de 1
    • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
  2. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: paso 2, imagen 1 de 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: paso 2, imagen 2 de 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: paso 2, imagen 3 de 3
    • Place the opening tool's head under any edge of the keyboard.
    • Pull upwards to unsnap the keyboard.
    • Use your fingers and the opening tool to pop the keyboard out of its place.
    • You should't use any excessive force because the keyboard is still attached to the motherboard.
  3. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: paso 3, imagen 2 de 2
    • Push the keyboard connector latch upwards with the spudger.
    • You shouldn't use excessive force. The connector latch is very fragile.
    • The keyboard connector cable should slide right out.
  4. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Optical Drive: paso 4, imagen 1 de 1
    • Remove the 6mm Phillips #1 screw that sits in the center of the front plate below the keyboard. This screw sits between two adjacent tabbed holes.
  5. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: paso 5, imagen 1 de 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: paso 5, imagen 2 de 3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: paso 5, imagen 3 de 3
    • Insert the opening tool's head into one of the tabbed holes.
    • With the opening tool's head inserted under a tab, push to the right. The optical drive should slide out easily.
Conclusión
Una persona más ha completado esta guía.
Ammar Dodin
Miembro Desde 01/19/17
1,057 Reputación
6 Guías creadas
Equipo
UC Davis, Team 1-3, Rodger Winter 2017 Miembro de UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 5,120
