Saltar al contenido principal
Lenovo IdeaPad 3-15IGL05 SSD Replacement
Qué necesitas
  1. Lenovo IdeaPad 3-15IGL05 SSD Replacement, SSD: paso 1, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the ten 7.6 mm screws securing the bottom panel.
  2. Lenovo IdeaPad 3-15IGL05 SSD Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 3-15IGL05 SSD Replacement: paso 2, imagen 2 de 2
    • Wedge an opening tool in the gap between the bottom panel and chassis, and pry vertically around the perimeter until you hear a "pop" and the panel releases.
    • Lift the bottom panel up and off the chassis.
  3. Lenovo IdeaPad 3-15IGL05 SSD Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad 3-15IGL05 SSD Replacement: paso 3, imagen 2 de 2
    • Locate the SSD at the bottom right corner of the fan.
    • Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the SSD.
    • The drive should slightly lift once the screw is removed.
  4. Lenovo IdeaPad 3-15IGL05 SSD Replacement: paso 4, imagen 1 de 1
    • Gently pull the SSD directly out of its port.
    • Do not over-tighten the screws during reassembly.
Conclusión
Matthew Frederic
Miembro Desde 09/30/21
109 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 87
Todo El Tiempo: 3,420
