Saltar al contenido principal
Lenovo IdeaPad 3-15ADA05 SSD Replacement
Qué necesitas
  1. Lenovo IdeaPad 3-15ADA05 SSD Replacement, SSD: paso 1, imagen 1 de 2 Lenovo IdeaPad 3-15ADA05 SSD Replacement, SSD: paso 1, imagen 2 de 2
    • Remove the 6 M2 x 5mm screws located at the top half of the laptop using a #0 phillips head, then remove the 4 M2 x 2.5mm screws located at the bottom of the laptop using a #0 phillips head.
  2. Lenovo IdeaPad 3-15ADA05 SSD Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 3-15ADA05 SSD Replacement: paso 2, imagen 2 de 2
    • Insert the pry pick between the base plate and the bottom of the laptop, and pry the clips loose around the edge until the base pops off.
  3. Lenovo IdeaPad 3-15ADA05 SSD Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad 3-15ADA05 SSD Replacement: paso 3, imagen 2 de 2
    • Locate the SSD underneath the blue thermal pad on the left side of the motherboard.
    • Peel back the thermal pad to reveal the screw.
  4. Lenovo IdeaPad 3-15ADA05 SSD Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad 3-15ADA05 SSD Replacement: paso 4, imagen 2 de 2
    • Using a #0 Phillips head, remove the M2 x 3mm screw securing the SSD.
    • The SSD should pop up at a slight angle.
  5. Lenovo IdeaPad 3-15ADA05 SSD Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad 3-15ADA05 SSD Replacement: paso 5, imagen 2 de 2
    • Slide the SSD out of the slot.
    • Try to keep the thermal pad in one piece to use on the replacement SSD.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 88
