Saltar al contenido principal
Lenovo IdeaPad 3-15ADA05 Fan Replacement
Qué necesitas
  1. Lenovo IdeaPad 3-15ADA05 Fan Replacement, Fan: paso 1, imagen 1 de 2 Lenovo IdeaPad 3-15ADA05 Fan Replacement, Fan: paso 1, imagen 2 de 2
    • Remove the six M2 x 5mm screws located at the top half of the laptop using a #0 Phillips head, then remove the four M2 x 2.5mm screws located at the bottom of the laptop using a #0 Phillips head.
  2. Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 2, imagen 2 de 2
    • Inset the opening pick between the base plate and the bottom of the laptop and pry the clips loose around the edge until the base pops off.
  3. Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 3, imagen 1 de 3 Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 3, imagen 2 de 3 Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 3, imagen 3 de 3
    • Remove the two M2 x 3.30mm screws using the #0 screw head, then remove the one M2 x 5mm screw using the #0 screw head.
  4. Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 4, imagen 1 de 3 Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 4, imagen 2 de 3 Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 4, imagen 3 de 3
    • Disconnect the black and white antenna cables from the wireless card using the opening tool.
  5. Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 5, imagen 1 de 3 Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 5, imagen 2 de 3 Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 5, imagen 3 de 3
    • Disconnect the fan cable from the motherboard using the opening tool.
  6. Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 6, imagen 1 de 3 Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 6, imagen 2 de 3 Lenovo IdeaPad 3-15ADA05 Fan Replacement: paso 6, imagen 3 de 3
    • Unwrap the cord from the three clips, then remove the fan.
    • To remove the cords, push them through the small gap shown by the arrow.
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 150
