Saltar al contenido principal
Lenovo IdeaPad 3-15ADA05 Battery Replacement
Qué necesitas
  1. Lenovo IdeaPad 3-15ADA05 Battery Replacement, Battery: paso 1, imagen 1 de 2 Lenovo IdeaPad 3-15ADA05 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the six M2 x 5mm screws located at the top half of the laptop using a #0 Phillips head, then remove the four M2 x 2.5mm screws located at the bottom of the laptop using a #0 Phillips head.
  2. Lenovo IdeaPad 3-15ADA05 Battery Replacement: paso 2, imagen 1 de 3 Lenovo IdeaPad 3-15ADA05 Battery Replacement: paso 2, imagen 2 de 3 Lenovo IdeaPad 3-15ADA05 Battery Replacement: paso 2, imagen 3 de 3
    • Insert the opening pick between the base plate and the bottom of the laptop, and pry the clips loose around the edge until the base pops off.
  3. Lenovo IdeaPad 3-15ADA05 Battery Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad 3-15ADA05 Battery Replacement: paso 3, imagen 2 de 2
    • Using a #0 Phillips head, remove the five M2 x 3.5mm screws holding the battery in place.
  4. Lenovo IdeaPad 3-15ADA05 Battery Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad 3-15ADA05 Battery Replacement: paso 4, imagen 2 de 2
    • Using the opening tool, disconnect the battery connector from the motherboard, and then remove the battery.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 89
