Introducción
Use this guide to replace the RAM in your Lenovo IdeaPad 3-14IIL05.
The RAM is the memory of the computer. If your computer is running slow, look in your task manager and observe to see if the RAM is the issue. If it is, consider upgrading.
Qué necesitas
Flip the laptop with the screen side facing down and the back panel facing you.
Remove the six 1.2 mm screws and the four 0.6 mm screws using a Phillips #1 screwdriver.
Hold the two clips on either end of the short side of the RAM and push them apart.
Remove the RAM.
