Saltar al contenido principal
Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement, Back Cover: paso 1, imagen 1 de 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement, Back Cover: paso 1, imagen 2 de 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement, Back Cover: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Orient the laptop so that the bottom is facing up.
    • Remove the six 7 mm screws using a Phillips #00 screwdriver.
    • Remove the four 4 mm screws using a Phillips #00 screwdriver.
  2. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: paso 2, imagen 1 de 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: paso 2, imagen 2 de 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: paso 2, imagen 3 de 3
    • Pry up the sides of the back case using the iFixit opening tool. Then, lift to remove.
    • You may hear snapping when removing the panel. This is normal!
  3. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 1 de 2 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement, Wi-Fi Card: paso 3, imagen 2 de 2
    • Use your fingernail or an opening tool to gently pull out and disconnect the battery pack cable.
    • Do not pull on the cables.
  4. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: paso 4, imagen 2 de 2
    • Use the spudger to remove each cable from the Wi-Fi card, one cable at a time.
    • The cables do not need much force to be removed.
  5. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: paso 5, imagen 1 de 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: paso 5, imagen 2 de 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: paso 5, imagen 3 de 3
    • Remove the single 2 mm screw using a Phillips #00 screwdriver.
    • Try not to press to hard down on the computer to avoid damage.
  6. Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: paso 6, imagen 1 de 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: paso 6, imagen 2 de 3 Lenovo IdeaPad 3-1481W000NGUS Wi-Fi Card Replacement: paso 6, imagen 3 de 3
    • Pull the card away from the housing capsule on the right side of the Wi-Fi card to remove it from the laptop.
    • Make sure no cables are still connected or wrapped around the Wi-Fi card when removing.
Conclusión
William Hart
Miembro Desde 03/01/23
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 17
Todo El Tiempo: 168
