Saltar al contenido principal
Lenovo IdeaPad 110-17IKB Fan Replacement
Qué necesitas
  1. Lenovo IdeaPad 110-17IKB Fan Replacement, Lower Case: paso 1, imagen 1 de 1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Fan Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 110-17IKB Fan Replacement: paso 2, imagen 2 de 2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Fan Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad 110-17IKB Fan Replacement: paso 3, imagen 2 de 2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Fan Replacement: paso 4, imagen 1 de 3 Lenovo IdeaPad 110-17IKB Fan Replacement: paso 4, imagen 2 de 3 Lenovo IdeaPad 110-17IKB Fan Replacement: paso 4, imagen 3 de 3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Fan Replacement, Fan: paso 5, imagen 1 de 2 Lenovo IdeaPad 110-17IKB Fan Replacement, Fan: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Unscrew the four 6 mm Phillips #0 screws that secure the fan.
    • Push the white fan connector directly out of its port using tweezers or a pry tool.
    • Lift the fan up and out of the chassis.
Conclusión
Cameron Mounce
Miembro Desde 09/05/23
668 Reputación
5 Guías creadas
Equipo
Gateway, Team 1-3, Pee Fall 2023 Miembro de Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 20
Todo El Tiempo: 114
