Saltar al contenido principal
Lenovo IdeaPad 110-171KB Battery Replacement
Qué necesitas
  1. Lenovo IdeaPad 110-171KB Battery Replacement, Battery: paso 1, imagen 1 de 2 Lenovo IdeaPad 110-171KB Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Insert an opening pick between the chassis and keyboard.
    • Gently slide the pick around the perimeter of the keyboard while prying until it releases completely.
    • Remove the keyboard.
  2. Lenovo IdeaPad 110-171KB Battery Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 110-171KB Battery Replacement: paso 2, imagen 2 de 2
    • Disconnect the cable connector from the motherboard.
    • Slide the cable out of the case.
  3. Lenovo IdeaPad 110-171KB Battery Replacement: paso 3, imagen 1 de 1
    • Place the the computer bottom facing up. Unscrew the eleven Phillips #0 6 mm screws.
  4. Lenovo IdeaPad 110-171KB Battery Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad 110-171KB Battery Replacement: paso 4, imagen 2 de 2
    • Pry the disk drive opposite of the laptop.
    • Since the screws has already been removed, you will not need to worry about any more screws on the optical drive.
  5. Lenovo IdeaPad 110-171KB Battery Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad 110-171KB Battery Replacement: paso 5, imagen 2 de 2
    • Release any of the remaining retaining clips and remove the lower case.
  6. Lenovo IdeaPad 110-171KB Battery Replacement: paso 6, imagen 1 de 3 Lenovo IdeaPad 110-171KB Battery Replacement: paso 6, imagen 2 de 3 Lenovo IdeaPad 110-171KB Battery Replacement: paso 6, imagen 3 de 3
    • Remove the two 9 mm Phillips #0 screws that secure the battery.
    • Remove the battery from the device.
Conclusión
Cameron Mounce
Miembro Desde 09/05/23
668 Reputación
5 Guías creadas
Equipo
Gateway, Team 1-3, Pee Fall 2023 Miembro de Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 163
