Introducción
If there is any physical damage done to the upper case, a replacement may be required based on the condition of the laptop. Follow the guide to replace the upper case of the laptop.
Qué necesitas
Flip the IdeaPad bottom side up.
Using a Phillips #1 screwdriver, remove the two 6.0mm screws on the back panel, that hold the keyboard.
Flip the computer back to top facing.
Using a Phillips #1 screwdriver, unscrew the one 5.0mm screw on the back panel.
Place the laptop bottom facing up.
Using a Phillips #1 screwdriver, remove the remaining eight 6.0mm screws on the back panel.
Una persona más ha completado esta guía.
