Herramientas
Partes
No se requieren partes.
  1. Remove the two keyboard screws on the back of the device(the two on the same row)
    • Remove the two keyboard screws on the back of the device(the two on the same row)
  2. Insert a prying tool in the crack between the keyboard and frame. Start by the power button and go all the way round the keyboard.
    • Insert a prying tool in the crack between the keyboard and frame. Start by the power button and go all the way round the keyboard.
  3. Remover the ribbon cable and remove the keyboard afterward.
    • Remover the ribbon cable and remove the keyboard afterward.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. After the keyboard is removed, remove the screw and the battery connector.
    • After the keyboard is removed, remove the screw and the battery connector.
  6. Remove the screw that is under the two keyboard screws and pull the disk drive out.
    • Remove the screw that is under the two keyboard screws and pull the disk drive out.
  7. Remove all of the screws on the outside edge of the bottom.
    • Remove all of the screws on the outside edge of the bottom.
  8. Flip the laptop over and in the crack between the two case pieces slide a prying tool in between and follow the perimeter until the two pieces are separated.
    • Flip the laptop over and in the crack between the two case pieces slide a prying tool in between and follow the perimeter until the two pieces are separated.
  9. Remove the four screws securing the drive bay into the case.
    • Remove the four screws securing the drive bay into the case.
  10. Remove the four screws the hold the metal cage onto the drive to separate them.
    • Remove the four screws the hold the metal cage onto the drive to separate them.
Conclusión
Una persona más ha completado esta guía.
Stuart Luhigo
Miembro Desde 20/11/18
169 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 43
