Saltar al contenido principal
Lenovo IdeaPad 110-15IBR Hard Drive Replacement
Qué necesitas
  1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: paso 1, imagen 1 de 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: paso 1, imagen 2 de 2
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source. Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Place laptop with the bottom facing up. Using a Philip #1 screwdriver unscrew all 13 screws. Gently pry the back out using a plastic opening tool, starting from one of the corners.
  2. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the four (5mm) screws holding the hard drive in place.
  3. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: paso 3, imagen 2 de 2
    • Do not lift hard drive straight up otherwise you might risk breaking the connection port.
    • Gently slide the hard drive away and out out of the connection port.
  4. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: paso 4, imagen 2 de 2
    • Using a Philip #1 screwdriver remove 2 screws from each side, (removing 4 screws in total) holding the hard drive into the housing.
  5. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: paso 5, imagen 1 de 1
    • Remove hard drive from housing.
Conclusión
To reassemble your device, follow these instructions in reverse order with your new replacement hard drive.
14 personas más completaron esta guía.
Equipo
UW Tacoma, Team S3-G4, Liner Fall 2017 Miembro de UW Tacoma, Team S3-G4, Liner Fall 2017
UWT-LINER-F17S3G4
4 Miembros
14 Guías creadas
3 comentarios
Unplug or remove battery first?
Chris Quirke - Contestar
you do not need to unplug or remove the battery
Holden Phillips - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 40
Todo El Tiempo: 19,911
