Saltar al contenido principal
Lenovo IdeaPad 110 Touch-15ACL Battery Replacement
Qué necesitas
  1. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement, Back Case: paso 1, imagen 1 de 1
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: paso 2, imagen 2 de 2
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: paso 3, imagen 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: paso 3, imagen 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: paso 3, imagen 3 de 3
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: paso 4, imagen 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: paso 4, imagen 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: paso 4, imagen 3 de 3
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement, Battery Replacement: paso 5, imagen 1 de 1
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: paso 6, imagen 1 de 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: paso 6, imagen 2 de 3 Lenovo IdeaPad 110 Touch-15ACL Battery Replacement: paso 6, imagen 3 de 3
    • Detach the wire connected to the motherboard and remove the battery assembly.
Conclusión
Addie
Miembro Desde 02/28/22
88 Reputación
1 Guía escrita
Equipo
Clemson, Team 2-3, Hunter Spring 2022 Miembro de Clemson, Team 2-3, Hunter Spring 2022
CLEM-HUNTER-S22S2G3
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 478
