Saltar al contenido principal
Lenovo IdeaPad 100s-14IBR Speaker Replacement
Qué necesitas
  1. Lenovo IdeaPad 100s-14IBR Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Speaker Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 100s-14IBR Speaker Replacement: paso 2, imagen 2 de 2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Speaker Replacement: paso 3, imagen 1 de 1
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with the nylon spudger.
    • Remove the six 4mm Phillips #00 screws.
    • Remove the battery using the nylon spudger.
  4. Lenovo IdeaPad 100s-14IBR Speaker Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad 100s-14IBR Speaker Replacement: paso 4, imagen 2 de 2
    • Unplug the speakers from the motherboard.
    • Remove the two 4mm PH00 screws from the metal shield on the trackpad.
    • Lift the metal shield up slightly, being very careful not to move the ribbon cables too much. Move the speaker cables out from under the shield.
  5. Lenovo IdeaPad 100s-14IBR Speaker Replacement: paso 5, imagen 1 de 1
    • Lift the speakers from the case being careful of the wires connecting them. Put them to the side.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 397
