Saltar al contenido principal
Introducción
This guide will help the users fix issues with storage in the Lenovo IdeaPad 100S-141BR.
  1. Remove the eight 4mm PH00 screws.
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Use the nylon spudger to loosen the back cover from the back of the device. You may hear a bit of a snapping sound, but this is normal.
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. For safety reasons, disconnect the wires connecting the battery to the motherboard with a nylon spudger.
    • For safety reasons, disconnect the wires connecting the battery to the motherboard with a nylon spudger.
  4. Remove the solid state drive.
    • Remove the solid state drive.
Conclusión
6 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 45
Ultimos 30 días: 229
Todo El Tiempo: 9,642
