Saltar al contenido principal
Qué necesitas
  1. Lenovo IdeaPad 100s-14IBR Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Battery Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 100s-14IBR Battery Replacement: paso 2, imagen 2 de 2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Battery Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad 100s-14IBR Battery Replacement: paso 3, imagen 2 de 2
    • Remove six 4mm Phillips #00 screws.
    • Pull the battery connector parallel to the motherboard to disconnect the battery from the motherboard.
  4. Lenovo IdeaPad 100s-14IBR Battery Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad 100s-14IBR Battery Replacement: paso 4, imagen 2 de 2
    • Use a nylon spudger to pry the battery up and out of the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 17
Ultimos 30 días: 58
Todo El Tiempo: 3,453
