Introducción
This is a guide on how to replace the touchpad on the Lenovo IdeaPad 1 14IGL7. You may need to consult this guide when your touchpad is no longer responsive, and you need to replace it. Please take precaution to not cause harm to the device.
Qué necesitas
Remove the six 5.5 mm screws that secure the battery using a Phillips #00 screwdriver.
Remove the three 3 mm screws that hold the metal bracket in place using a Phillips #00 screwdriver.
